Doorless Mirror
13K views 34 replies 18 participants last post by  StepsRide
#1 ·
So what is everyone using for replacement/relocation side mirrors...if any...when running doorless?
#11 ·
Dietech brackets FTW! They are pricey, they use your stock mirrors and they put them just about in the stock location. Most important aspect to me, NO VIBRATIONS!!!
#19 ·
I have the Mopar side mirror kit that has a bracket that bolts to the windshield bracket... the mirror bolts to that. The Mopar one isn't available anymore but Quadratec carries one just like it.
#24 ·
I just bought a replacement mirror from napa and then bolted it to a 90deg bracket from Lowes, add a vinyl washer and your set. Remove one bolt from the side of the windshield bracket and use it to attach the bracket and mirror. total cost for parts - $12, time to install and remove - under a min.
(I only run a driver side, I can turn my head for the passenger)
#29 ·
I run the Dietec brackets. They mount the mirror in the exact same place as the door. You can use the mirror off your door or do what I did, get a second set from the salvage yard. only takes a couple of minutes to put them on. Cost a bit more but its a very factory looking install.
More Info
http://www.jkowners.com/forum/showthread.php?t=33953
#30 ·
/thread
Well worth the money.
