#1 |
Member # 120
Atlas II Install
We put an Atlas II in our 2 dr X model. IT has 4.88 gears, 6 spd and 35 " tires so we chose a 5.0 ratio. Overall the install was pretty straigt forward. The only problems will be what to do with the drivelines. We already had the JE Reel bolt in drivelines so I figured out a way to put everything together without having to lengthen or shorten them.
Here is the new unit ready for installation. |
#2 |
Member # 120
I used the stock JK front yoke on the rear of the atlas, I don't remember why I didn't use the rear one, but it does have that damper on it. With the stock yoke on the rear of the atlas, it is very close to the length of the stock JK t-case so the rear driveline bolted in.
#3 |
Member # 120
To use the stock JK front yoke on the atlas I had to remove the dust seal/slinger from the yoke. Also the JK pinion nut had a much larger flange than the atlas one, and it needs it. I had to use a washer under the atlas pinion nut.
#4 |
Member # 120
The front yoke of the Atlas is further forward than the JK one so the driveline needs to be shorter. I used a standard 1310 CV yoke you can get with the atlas and removed the JK yoke adapter from the JE Reel drive shaft and the drive line bolted up without shortening.
#5 |
Member # 120
The atlas JK install requires a cable shifter, they have a special JK shifter for this. It was easy and straight forward. The cables go through the hole where the stock shifter cable went through the floor. There was some minor trimming to the console for the shifter handles but over all a clean install.
#6 |
Member # 120
Some finished install pics
#7 |
Member # 79
Nice writeup! You had a chance to test it out yet?
__________________
2007 Rubicon Unlimited: MODS: Superior 5.13 Gears, Black Diamond 3" Lift, 1" M.O.R.E. Body Lift, FT Rear Adj. Trackbar, 15x8 ION 170 wheels, 37x12.50x15 Goodyear MT/R's, Superwinch EPi9.0, Smittybilt SRC front bumper, IGGEE Black/Charcoal seat covers, relocated muffler (Magnaflow 11376). http://www.RedRockJK.com |
#8 |
Broker by the Minute
That is a thing of beauty!
5:1 has got to be awesome! I'm jealous. |
#9 |
Member # 120
We have had it in since late May, it has been through the Rubicon both ways 3 times. It works great, really glad to have the 5.0 with the 6 spd. I haven't driven it much though, Dave (PIG) has used it most, for some reason he thinks its OK to do front digs with a dana 30 and 35" Krawlers. |
#10 |
Parts slinger
Member # 387
Very NICE!
![]() I want to be there for the subsequent of a D30 doing a front dig.
#11 | |
Yep, I'm thinking shiat will be a flying!
#12 |
Member # 120
I did put together a super 30 with ARB and chromoly shafts a while ago, I'll do a write up on that when I get a chance.
#13 | |
homo predmostensis
Member # 48
#14 |
Member # 119
LOL.....
#15 | |
Administrator
#16 | |
Member # 119
Edit: (pun intended.) |
#17 |
Member # 305
Think a 4 speed atlas with a shorty output would fit? I noticed that you didn't have to use the speedo-hole at all?
#18 |
Member # 418
I was told that the shorty doesn't have the bearings it would need to be in a DD. They would be shot in just a couple hundred miles so I got the normal length Atlas II 4spd. I am going to install it here real soon so I will post up results.
#19 |
Member # 120
The JK does not use a speedo gear/sensor in the t-case like the TJ, it uses the ABS sensors at the wheels.
__________________
Those of you that think you know everything really annoy those of us that do! POLYPERFORMANCE |
#20 |
Member # 28
God I hate you......................well maybe not hate, but envy, the 4:1 rubi is nice but that twin stick 5:1 with 4.88 will be nice. I saw a 6:1 out there somewhere. what will your crawl ration be with that set up, i cant remember the formula.
__________________
2007 Rubi 2 1/2" BB, 35's River Raider Tube Fenders, Warn Front bumper, 9k winch. 2000 Ford Explorer Lifted on 33's (Dead) Roll over) 2007 Sportsman 800 2003 Suzuki Eigor 4x4 (Dead rearended the Sportsman, Guts transfered to a Golfcart) 199? Yamaha Banshee |
#21 |
Member # 119
(R&P) X (Low Range Ratio) X (1st Gear Ratio) = Final Crawl Ratio
#22 |
Member # 482
wow so around 125:1 final crawl.. nice
__________________
The Herd of Turtles |
#23 |
Member # 119
We have some Rock Jocks on the way now which will be filled with some 5.38's so we gonna go a little lower.
#24 | |
Member # 204
Will you have the ESP disabled or are these the ones that keep the stock brakes and stuff? |
#25 |
Member # 119
The RockJock units allow for the use of the factory outer components.
| Thread Tools | |
| Display Modes | |
